[PROJ] Ellipsoidal distances, with different heights
Even Rouault even.rouault at spatialys.com
Wed Aug 28 03:04:05 PDT 2024
Or even simpler, compute geodesic distance on ellipsoid (a + h_mean, b +
h_mean) where h_mean is the mean of h_start and h_end.  If h_start and
h_end are small compared to a, I would expect whatever mean formula used
to lead to similar results. At least this method is guaranteed to give
the correct result when h_start = h_end = 0 ...
Le 28/08/2024 à 01:36, Even Rouault via PROJ a écrit :
> Nyall,
> I'm not sure there's a real definition to what you want to accomplish.
> I guess I would :
> - use the geod_position() of geodesic.h to compute a sufficient number
> of intermediate positions
> - linearly interpolate the ellipsoidal height
> - convert the resulting (lon, lat, h) to geocentric (X, Y, Z) using
> +proj=cart
> - use 3D Cartesian distance to compute each intermediate segment
> - sum them up
> A cheaper alternative might be to compute the geodesic distance
> between the start and end points both on the ellipsoid (a + h_start, b
> + h_start) and on the one (a + h_end, b + h_end), and compute some
> sort of mean (arithmetic, geometry, ... ?) on those 2 distances.
> Even
> Le 28/08/2024 à 01:06, Nyall Dawson via PROJ a écrit :
>> Hi list,
>> Let's say I have two points on an ellipsoid, with each point having a
>> different height above the ellipsoid. I want to calculate a kind of
>> "geodesic" between these points, where there's an assumption that the
>> gradient of the height-above-ellipsoid for the "geodesic" is constant.
>> Is this mathematically solvable? Or, more to the point, is it possible
>> to calculate this using any of the methods exposed via geodesic.h?
>> Nyall
>> PROJ mailing list
>> PROJ at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
More information about the PROJ mailing list
