[PROJ] Ellipsoidal distances, with different heights
Mircea Neacsu
mircea at neacsu.net
Wed Aug 28 11:52:49 PDT 2024
You can also see the lecture notes on geodetic positions computations at https://gge.ext.unb.ca/Pubs/LN39.pdf
Mircea Neacsu
---- On Tue, 27 Aug 2024 19:06:00 -0400 Nyall Dawson via PROJ <proj at lists.osgeo.org> wrote ---
Hi list,
Let's say I have two points on an ellipsoid, with each point having a
different height above the ellipsoid. I want to calculate a kind of
"geodesic" between these points, where there's an assumption that the
gradient of the height-above-ellipsoid for the "geodesic" is constant.
Is this mathematically solvable? Or, more to the point, is it possible
to calculate this using any of the methods exposed via geodesic.h?
Nyall
PROJ mailing list
mailto:PROJ at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240828/f3be68bd/attachment.htm>
More information about the PROJ
