[PROJ] Custom PROJ_DATA_PATH Output Directory
Even Rouault even.rouault at spatialys.com
Tue Dec 3 08:48:13 PST 2024
> /CMakeLists.txt
> set(PROJ_DATA_PATH "${CMAKE_INSTALL_FULL_DATADIR}/proj")
> to
> set(PROJ_DATA_PATH "${CMAKE_INSTALL_FULL_DATADIR}/somethingElse")
> Is there a better way to do this? Or could we add a new cmake
> parameter to override either the end piece or the whole thing if it's
> set? Call it PROJ_DATA_OUTPUT_PATH or PROJ_DATA_PATH_OVERRIDE?
Make PROJ_DATA_PATH a CACHE variable with a default value to
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20241203/179d4fb0/attachment.htm>
More information about the PROJ mailing list
