[PROJ] Custom PROJ_DATA_PATH Output Directory
Greg Troxel gdt at lexort.com
Tue Dec 3 09:35:05 PST 2024
Why do people want to install proj to non-standard names?    Most
packages do not support renaming, so I find it strange that this is
desirable.   The standard approach if you need two versions of anything
is to use different prefixes.  Can you explain the need?
More information about the PROJ mailing list
