[PROJ] Unexpected error in +proj=horner +inv
Lesparre, Jochem
Jochem.Lesparre at kadaster.nl
Wed Dec 11 02:46:49 PST 2024
Hi list,
I tried a polynomial transformation published in 1925 and it works fine for the forward transformation:
(echo 30000.00 100000.00 & echo 30000.00 120000.00) | cct -d 2 -z 0 +proj=horner +deg=3 +fwd_origin=0,0 +fwd_u=+120025.8705,+0.999986846,-0.0250515e-8,+0.1471965e-14,+0.006918172,-0.0860518e-8,-0.0398590e-14,+0.0011249e-8,+0.4556545e-14,+0.1991105e-14 +fwd_v=+390181.7849,+0.999993024,-0.0338879e-8,+0.1184845e-14,-0.006907254,-0.0492600e-8,-0.1945916e-14,+0.0222878e-8,+0.9244571e-14,-0.1091684e-14 +inv_tolerance=0.001
150717.96 489970.61 0.00 inf
150857.90 509969.45 0.00 inf
However, it gives an error for any input with a Northing greater than 500000 for the inverse transformation:
(echo 150717.96 489970.61 & echo 150857.90 509969.45) | cct -d 2 -z 0 +proj=horner +deg=3 +fwd_origin=0,0 +fwd_u=+120025.8705,+0.999986846,-0.0250515e-8,+0.1471965e-14,+0.006918172,-0.0860518e-8,-0.0398590e-14,+0.0011249e-8,+0.4556545e-14,+0.1991105e-14 +fwd_v=+390181.7849,+0.999993024,-0.0338879e-8,+0.1184845e-14,-0.006907254,-0.0492600e-8,-0.1945916e-14,+0.0222878e-8,+0.9244571e-14,-0.1091684e-14 +inv_tolerance=0.001 +inv
30000.00 100000.00 0.00 inf
# Record 1 TRANSFORMATION ERROR: 150857.90 509969.45
(Point outside of projection domain)
Is this a problem with the original polynomial transformation or a bug in PROJ?
Regards, Jochem
Disclaimer:
De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd voor de geadresseerde(n).
Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of verstrekking van deze informatie aan derden is niet toegestaan.
Op al onze producten en diensten zijn onze algemene leveringsvoorwaarden van toepassing
[https://www.kadaster.nl/algemene-leveringsvoorwaarden].
Disclaimer:
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Our general terms and conditions of delivery apply to all our products and services
[https://www.kadaster.com/general-terms-and-conditions].
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20241211/f0e7e0e4/attachment.htm>
More information about the PROJ
