[PROJ] Unexpected error in +proj=horner +inv
Javier Jimenez Shaw j1 at jimenezshaw.com
Wed Dec 11 06:02:56 PST 2024
Hi Jochem
After looking at the code, this error happens when the coordinates are out
of range. The default value for that range is 500000
You can change it with
https://proj.org/en/stable/operations/transformations/horner.html#cmdoption-arg-range
I hope it helps
On Wed, 11 Dec 2024 at 11:54, Lesparre, Jochem via PROJ <
proj at lists.osgeo.org> wrote:
> Hi list,
> I tried a polynomial transformation published in 1925 and it works fine
> for the forward transformation:
> (echo 30000.00 100000.00 & echo 30000.00 120000.00) | cct -d 2 -z 0
> +proj=horner +deg=3 +fwd_origin=0,0
> +fwd_u=+120025.8705,+0.999986846,-0.0250515e-8,+0.1471965e-14,+0.006918172,-0.0860518e-8,-0.0398590e-14,+0.0011249e-8,+0.4556545e-14,+0.1991105e-14
> +fwd_v=+390181.7849,+0.999993024,-0.0338879e-8,+0.1184845e-14,-0.006907254,-0.0492600e-8,-0.1945916e-14,+0.0222878e-8,+0.9244571e-14,-0.1091684e-14
> +inv_tolerance=0.001
>     150717.96      489970.61          0.00           inf
>     150857.90      509969.45          0.00           inf
> However, it gives an error for any input with a Northing greater than
> 500000 for the inverse transformation:
> (echo 150717.96 489970.61 & echo 150857.90 509969.45) | cct -d 2 -z 0
> +inv_tolerance=0.001 +inv
>      30000.00      100000.00          0.00           inf
> # Record 1 TRANSFORMATION ERROR: 150857.90 509969.45
> (Point outside of projection domain)
> Is this a problem with the original polynomial transformation or a bug in
> PROJ?
> Regards, Jochem
> Disclaimer:
> De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd voor de
> geadresseerde(n).
> Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of
> verstrekking van deze informatie aan derden is niet toegestaan.
> Op al onze producten en diensten zijn onze algemene leveringsvoorwaarden
> van toepassing
> [https://www.kadaster.nl/algemene-leveringsvoorwaarden].
> Disclaimer:
> This email and any files transmitted with it are confidential and intended
> solely for the use of the individual or entity to whom they are addressed.
> If you are not the intended recipient, you are notified that disclosing,
> copying, distributing or taking any action in reliance on the contents of
> this information is strictly prohibited.
> Our general terms and conditions of delivery apply to all our products and
> services
> [https://www.kadaster.com/general-terms-and-conditions].
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20241211/1374b1c3/attachment.htm>
More information about the PROJ mailing list
