[PROJ] Unexpected error in +proj=horner +inv
Lesparre, Jochem
Jochem.Lesparre at kadaster.nl
Wed Dec 11 06:48:47 PST 2024
Hi Javier,
Thanks! That helps:
(echo 150717.96 489970.61 & echo 150857.90 509969.45) | cct -d 2 -z 0 +proj=horner +deg=3 +fwd_origin=0,0 +fwd_u=+120025.8705,+0.999986846,-0.0250515e-8,+0.1471965e-14,+0.006918172,-0.0860518e-8,-0.0398590e-14,+0.0011249e-8,+0.4556545e-14,+0.1991105e-14 +fwd_v=+390181.7849,+0.999993024,-0.0338879e-8,+0.1184845e-14,-0.006907254,-0.0492600e-8,-0.1945916e-14,+0.0222878e-8,+0.9244571e-14,-0.1091684e-14 +inv_tolerance=0.001 +inv +range=600000
30000.00 100000.00 0.00 inf
30000.00 120000.00 0.00 inf
I did try specifying the range before, but I did not try such a large value. Due to the word “radius” in the description at https://proj.org/en/stable/operations/transformations/horner.html#cmdoption-arg-range I expected the range value to specify a circle instead of a box. More importantly, I expected it to apply on the input coordinates in the forward transformation and the output coordinates in the inverse transformation. I think the latter would make more sense, as that would mean one can use the same +range for the forward and inverse transformation. Therefore I would like to suggest a change in the code instead of only making the documentation more comprehensive.
Jochem
Disclaimer:
De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd voor de geadresseerde(n).
Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of verstrekking van deze informatie aan derden is niet toegestaan.
Op al onze producten en diensten zijn onze algemene leveringsvoorwaarden van toepassing
[https://www.kadaster.nl/algemene-leveringsvoorwaarden].
Disclaimer:
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Our general terms and conditions of delivery apply to all our products and services
[https://www.kadaster.com/general-terms-and-conditions].
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20241211/6277ae85/attachment-0001.htm>
More information about the PROJ
