[PROJ] Issue with inverted axis
Javier Jimenez Shaw j1 at jimenezshaw.com
Tue Jul 30 05:37:36 PDT 2024
Hi Mladen,
In which context do you want to do that? python? C++? CLI? What are you
doing later with that info (like calling cs2cs or anything else)?
If you just want to know for a few cases,
https://spatialreference.org/ref/epsg/2193/ is an easy reference. There is
axis information.
Cheers
On Tue, 30 Jul 2024 at 14:11, Mladen Mijatovic via PROJ <
proj at lists.osgeo.org> wrote:
> Hi all,
> Is there a way to identify if crs has an inverted axis? In most of the
> cases axes are Lat,Lon or E,N but I stumbled on one with axis N,E -
> EPSG:2193. In this case I need to invert coordinates before the
> transformation and I am not sure how to identify this situation in general.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240730/743f24a1/attachment.htm>
More information about the PROJ mailing list
