[PROJ] PROJ 9.4.1RC1 & PROJ-data 1.18RC1
Charles Karney charles.karney at gmail.com
Sat Jun 1 05:35:25 PDT 2024
+1
--Charles
On Sat, Jun 1, 2024 at 1:23 AM Kristian Evers via PROJ
<proj at lists.osgeo.org> wrote:
> Apart from the issue with the ._-files in the PROJ-data packages no issues has been reported. I hereby motion that both release candidates be promoted to final releases. I'll start with my +1.
> /Kristian
> man. 27. maj 2024 21.42 skrev Kristian Evers <kristianevers at gmail.com>:
>> All,
>> It’s time for another round of releases, so in preparation for the final packages I have uploaded
>> release candidates for PROJ and PROJ-data. Download the archives here:
>> https://download.osgeo.org/proj/proj-9.4.1RC1.tar.gz
>> https://download.osgeo.org/proj/proj-9.4.1RC1.zip
>> https://download.osgeo.org/proj/proj-data-1.18RC1.tar.gz
>> https://download.osgeo.org/proj/proj-data-1.18RC1.zip
>> The PROJ release includes updates to the database contents and bug fixes. See the release notes below.
>> The PROJ-data release adds transformation models for the Danish vertical CRS’s DKLAT and DKMSL as well
>> as the Greenlandic GLLMSL.
>> Please test the release candidates and report any issues you may find. Either here on the mailing list or on GitHub.
>> /Kristian
>> # PROJ Release Notes
>> ## 9.4.1
>> ### Updates
>> * Database: update to EPSG v11.006 (#4086)
>> * Database: update ESRI dataset to ArcGIS Pro 3.3 (#4143)
>> ### Bug fixes
>> * DatabaseContext::lookForGridInfo(): do not trigger network activity in
>> PROJ_GRID_AVAILABILITY_KNOWN_AVAILABLE mode when all grids are known (#4090)
>> * Retry "Connection reset by peer" (#4107)
>> * Use unique names for NKG transformations (#4111)
>> * proj_create()/proj_create_from_database(): recall CRS AUTH:CODE in error message (#4114)
>> * DerivedProjectedCRS: deal with lack of explicit CS in BASEPROJCRS in WKT (#4139)
>> * proj_symbol_rename.h: update with current symbols (#4145)
>> * Improve detection of compatible/incompatible celestial bodies (#4150)
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
Charles Karney <karney at alum.mit.edu>
702 Prospect Ave
Princeton, NJ 08540
More information about the PROJ mailing list
