[PROJ] PROJ 9.4.1RC1 & PROJ-data 1.18RC1
Kristian Evers
kristianevers at gmail.com
Sat Jun 1 06:45:23 PDT 2024
With +1’s from
Kristian
Javier
Even
Thomas
Alan
Charles
I declare the motion passed. Release announcement will follow shortly.
/Kristian
> On 1 Jun 2024, at 14.35, Charles Karney <charles.karney at gmail.com> wrote:
> +1
> --Charles
> On Sat, Jun 1, 2024 at 1:23 AM Kristian Evers via PROJ
> <proj at lists.osgeo.org> wrote:
>> Apart from the issue with the ._-files in the PROJ-data packages no issues has been reported. I hereby motion that both release candidates be promoted to final releases. I'll start with my +1.
>> /Kristian
>> man. 27. maj 2024 21.42 skrev Kristian Evers <kristianevers at gmail.com>:
>>> All,
>>> It’s time for another round of releases, so in preparation for the final packages I have uploaded
>>> release candidates for PROJ and PROJ-data. Download the archives here:
>>> https://download.osgeo.org/proj/proj-9.4.1RC1.tar.gz
>>> https://download.osgeo.org/proj/proj-9.4.1RC1.zip
>>> https://download.osgeo.org/proj/proj-data-1.18RC1.tar.gz
>>> https://download.osgeo.org/proj/proj-data-1.18RC1.zip
>>> The PROJ release includes updates to the database contents and bug fixes. See the release notes below.
>>> The PROJ-data release adds transformation models for the Danish vertical CRS’s DKLAT and DKMSL as well
>>> as the Greenlandic GLLMSL.
>>> Please test the release candidates and report any issues you may find. Either here on the mailing list or on GitHub.
>>> /Kristian
>>> # PROJ Release Notes
>>> ## 9.4.1
>>> ### Updates
>>> * Database: update to EPSG v11.006 (#4086)
>>> * Database: update ESRI dataset to ArcGIS Pro 3.3 (#4143)
>>> ### Bug fixes
>>> * DatabaseContext::lookForGridInfo(): do not trigger network activity in
>>> PROJ_GRID_AVAILABILITY_KNOWN_AVAILABLE mode when all grids are known (#4090)
>>> * Retry "Connection reset by peer" (#4107)
>>> * Use unique names for NKG transformations (#4111)
>>> * proj_create()/proj_create_from_database(): recall CRS AUTH:CODE in error message (#4114)
>>> * DerivedProjectedCRS: deal with lack of explicit CS in BASEPROJCRS in WKT (#4139)
>>> * proj_symbol_rename.h: update with current symbols (#4145)
>>> * Improve detection of compatible/incompatible celestial bodies (#4150)
>> PROJ mailing list
>> PROJ at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/proj
> Charles Karney <karney at alum.mit.edu>
> 702 Prospect Ave
> Princeton, NJ 08540
More information about the PROJ
