[PROJ] PROJ 9.4.1 & PROJ-data 1.18
Javier Jimenez Shaw
j1 at jimenezshaw.com
Sat Jun 1 10:17:52 PDT 2024
Thanks Kristian.
Are the docker images for the releases generated automatically? It is not
there (three hours after your email)
In case it is a manual step, I do not see anything in
https://github.com/OSGeo/PROJ/blob/master/HOWTO-RELEASE.md (or I missed it)
Cheers,
Javier.
On Sat, 1 Jun 2024 at 16:09, Kristian Evers via PROJ <proj at lists.osgeo.org>
wrote:
> I'm happy to announce the release of PROJ 9.4.1 and PROJ-data 1.18!
> The PROJ release includes updates to the the database contents, as well as
> a number of bug fixes. See the release notes below.
> The PROJ-data release adds transformation models for DKLAT, DKMSL and
> GLLMSL.
> Download the archives here:
> http://download.osgeo.org/proj/proj-9.4.1.tar.gz
> http://download.osgeo.org/proj/proj-9.4.1.zip
> http://download.osgeo.org/proj/proj-data-1.18.tar.gz
> http://download.osgeo.org/proj/proj-data-1.18.zip
> /Kristian
> # 9.4.1 Release notes
> ## Updates
> * Database: update to EPSG v11.006 (#4086)
> * Database: update ESRI dataset to ArcGIS Pro 3.3 (#4143)
> ## Bug fixes
> * DatabaseContext::lookForGridInfo(): do not trigger network activity in
> PROJ_GRID_AVAILABILITY_KNOWN_AVAILABLE mode when all grids are known
> (#4090)
> * Retry "Connection reset by peer" (#4107)
> * Use unique names for NKG transformations (#4111)
> * proj_create()/proj_create_from_database(): recall CRS AUTH:CODE in error
> message (#4114)
> * DerivedProjectedCRS: deal with lack of explicit CS in BASEPROJCRS in WKT
> (#4139)
> * proj_symbol_rename.h: update with current symbols (#4145)
> * Improve detection of compatible/incompatible celestial bodies (#4150)
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240601/404decc9/attachment-0001.htm>
More information about the PROJ
