[PROJ] PROJ 9.4.1 & PROJ-data 1.18
Even Rouault even.rouault at spatialys.com
Sat Jun 1 10:45:51 PDT 2024
Hum, this is probably the result of
https://github.com/OSGeo/PROJ/commit/23d50be12ea5c35041f08e69556b5e050f6b4073
which removed docker.yml from the 9.4 branch. I believe the reason is
that I found that pushes in the 9.4 branch resulted in the proj-docs
Docker image being overwritten by the version of the Dockerfile in the
9.4 branch instead of the updated one from master. But I overlooked the
effect on the Docker proj image itself.  So removing the whole
Dockerfile from the maintenance branch is not the right thing to do.
I've filed https://github.com/OSGeo/PROJ/issues/4156 so we fix that
I'm manually building the image locally, and will push it.
Le 01/06/2024 à 19:17, Javier Jimenez Shaw via PROJ a écrit :
> Thanks Kristian.
> Are the docker images for the releases generated automatically? It is
> not there (three hours after your email)
> In case it is a manual step, I do not see anything in
> https://github.com/OSGeo/PROJ/blob/master/HOWTO-RELEASE.md (or I
> missed it)
> Cheers,
> Javier.
> On Sat, 1 Jun 2024 at 16:09, Kristian Evers via PROJ
> <proj at lists.osgeo.org> wrote:
>     I'm happy to announce the release of PROJ 9.4.1 and PROJ-data 1.18!
>     The PROJ release includes updates to the the database contents, as
>     well as
>     a number of bug fixes. See the release notes below.
>     The PROJ-data release adds transformation models for DKLAT, DKMSL
>     and GLLMSL.
>     Download the archives here:
>     http://download.osgeo.org/proj/proj-9.4.1.tar.gz
>     http://download.osgeo.org/proj/proj-9.4.1.zip
>     http://download.osgeo.org/proj/proj-data-1.18.tar.gz
>     http://download.osgeo.org/proj/proj-data-1.18.zip
>     /Kristian
>     # 9.4.1 Release notes
>     ## Updates
>     * Database: update to EPSG v11.006 (#4086)
>     * Database: update ESRI dataset to ArcGIS Pro 3.3 (#4143)
>     ## Bug fixes
>     * DatabaseContext::lookForGridInfo(): do not trigger network
>     activity in
>     PROJ_GRID_AVAILABILITY_KNOWN_AVAILABLE mode when all grids are
>     known (#4090)
>     * Retry "Connection reset by peer" (#4107)
>     * Use unique names for NKG transformations (#4111)
>     * proj_create()/proj_create_from_database(): recall CRS AUTH:CODE
>     in error message (#4114)
>     * DerivedProjectedCRS: deal with lack of explicit CS in
>     BASEPROJCRS in WKT (#4139)
>     * proj_symbol_rename.h: update with current symbols (#4145)
>     * Improve detection of compatible/incompatible celestial bodies
>     (#4150)
>     _______________________________________________
>     PROJ mailing list
>     PROJ at lists.osgeo.org
>     https://lists.osgeo.org/mailman/listinfo/proj
> PROJ mailing list
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240601/c5eb651b/attachment.htm>
More information about the PROJ mailing list
