[PROJ] PROJ 9.4.1 & PROJ-data 1.18
Even Rouault
even.rouault at spatialys.com
Sat Jun 1 11:25:59 PDT 2024
ghcr.io/osgeo/proj:9.4.1 and docker.io/osgeo/proj:9.4.1 are now available
Generated with:
git checkout 9.4.1
docker build . -t ghcr.io/osgeo/proj:9.4.1
docker tag ghcr.io/osgeo/proj:9.4.1 docker.io/osgeo/proj:9.4.1
docker push ghcr.io/osgeo/proj:9.4.1
docker push docker.io/osgeo/proj:9.4.1
Le 01/06/2024 à 19:45, Even Rouault via PROJ a écrit :
> Hum, this is probably the result of
> https://github.com/OSGeo/PROJ/commit/23d50be12ea5c35041f08e69556b5e050f6b4073
> which removed docker.yml from the 9.4 branch. I believe the reason is
> that I found that pushes in the 9.4 branch resulted in the proj-docs
> Docker image being overwritten by the version of the Dockerfile in the
> 9.4 branch instead of the updated one from master. But I overlooked
> the effect on the Docker proj image itself. So removing the whole
> Dockerfile from the maintenance branch is not the right thing to do.
> I've filed https://github.com/OSGeo/PROJ/issues/4156 so we fix that
> I'm manually building the image locally, and will push it.
> Le 01/06/2024 à 19:17, Javier Jimenez Shaw via PROJ a écrit :
>> Thanks Kristian.
>> Are the docker images for the releases generated automatically? It is
>> not there (three hours after your email)
>> In case it is a manual step, I do not see anything in
>> https://github.com/OSGeo/PROJ/blob/master/HOWTO-RELEASE.md (or I
>> missed it)
>> Cheers,
>> Javier.
>> On Sat, 1 Jun 2024 at 16:09, Kristian Evers via PROJ
>> <proj at lists.osgeo.org> wrote:
>> I'm happy to announce the release of PROJ 9.4.1 and PROJ-data 1.18!
>> The PROJ release includes updates to the the database contents,
>> as well as
>> a number of bug fixes. See the release notes below.
>> The PROJ-data release adds transformation models for DKLAT, DKMSL
>> and GLLMSL.
>> Download the archives here:
>> http://download.osgeo.org/proj/proj-9.4.1.tar.gz
>> http://download.osgeo.org/proj/proj-9.4.1.zip
>> http://download.osgeo.org/proj/proj-data-1.18.tar.gz
>> http://download.osgeo.org/proj/proj-data-1.18.zip
>> /Kristian
>> # 9.4.1 Release notes
>> ## Updates
>> * Database: update to EPSG v11.006 (#4086)
>> * Database: update ESRI dataset to ArcGIS Pro 3.3 (#4143)
>> ## Bug fixes
>> * DatabaseContext::lookForGridInfo(): do not trigger network
>> activity in
>> PROJ_GRID_AVAILABILITY_KNOWN_AVAILABLE mode when all grids are
>> known (#4090)
>> * Retry "Connection reset by peer" (#4107)
>> * Use unique names for NKG transformations (#4111)
>> * proj_create()/proj_create_from_database(): recall CRS AUTH:CODE
>> in error message (#4114)
>> * DerivedProjectedCRS: deal with lack of explicit CS in
>> BASEPROJCRS in WKT (#4139)
>> * proj_symbol_rename.h: update with current symbols (#4145)
>> * Improve detection of compatible/incompatible celestial bodies
>> (#4150)
>> PROJ mailing list
>> PROJ at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/proj
>> PROJ mailing list
> http://www.spatialys.com
> My software is free, but my time generally not.
> PROJ mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240601/1dfa47a3/attachment.htm>
More information about the PROJ
