[PROJ] intersects function
Javier Jimenez Shaw
j1 at jimenezshaw.com
Sat Jun 8 12:33:56 PDT 2024
Hi
I am having a look at
bool GeographicBoundingBox::Private::intersects(const Private &other) const
(at metadata.cpp
https://github.com/OSGeo/PROJ/blob/e0e14829a404672adcf494057d7d70cfc8f96905/src/iso19111/metadata.cpp#L315
And I see something estrange
The function starts with 3 if statements:
if (N < oS || S > oN) {
return false;
if (W == -180.0 && E == 180.0 && oW > oE) {
return true;
if (oW == -180.0 && oE == 180.0 && W > E) {
return true;
The first is clear: checks the intersection in the N-S range.
But the second and third I would expect
if (W == -180.0 && E == 180.0) {
return true;
if (oW == -180.0 && oE == 180.0) {
return true;
if it covers the whole planet (from -180 to 180) it clearly intersects,
right? Or am I missing something? (after is passes the first if statement
on N-S)
I am not trying to optimize the method, but just to understand it (I am
implementing it in javascript)
Thanks.
.___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240608/b02c5605/attachment.htm>
More information about the PROJ
