[PROJ] PROJ was not updated in Zenodo
Even Rouault
even.rouault at spatialys.com
Wed Jun 19 01:43:22 PDT 2024
The Zenodo team has imported the 9.4.1 release and have logged an issue
about the disabling of the repos.
Even
Le 04/06/2024 à 16:25, Even Rouault via PROJ a écrit :
> Hi,
> I've posted the following message through Zenodo support form at
> https://zenodo.org/support
> Hi,
> The PROJ project has released a new GitHub release at
> https://github.com/OSGeo/PROJ/releases/tag/9.4.1 a couple days ago but
> no new corresponding Zenodo record has been created at
> https://zenodo.org/records/5884394 , despite the GitHub integration
> being set up.
> I see from my account in https://zenodo.org/account/settings/github/
> that the repository seems to have been disabled, although it was
> enabled last time. It seems something regularly disable
> repositories... ? I've just re-enabled it (as well as other
> repositories such as OSGeo/gdal and mapserver/mapserver that were
> disabled). Could you trigger the creation of a new record for the
> 9.4.1 release ? And what's the reason for this apparent disabling of
> repositories? This isn't the first time it happens
> Best regards,
> Even Rouault
> I'm proposing to add a step in HOWTO-RELEASE so we check that before
> doing the release : https://github.com/OSGeo/PROJ/pull/4162 , pending
> Zenodo figures out why the repositories get regularly disabled...
> Even
> Le 04/06/2024 à 12:20, Peter Löwe via PROJ a écrit :
>> Javier, all,
>> whoever handled the latest release should contact the Zenodo helpdesk
>> https://zenodo.org/support about the missing version DOI.
>> BTW, the PROJ page at OSGeo (https://www.osgeo.org/projects/proj/)
>> seems to be outdated (PROJ 9.0.0).
>> Best,
>> Peter
>> <peter.loewe at gmx.de>
>> *Gesendet:* Montag, 03. Juni 2024 um 21:56 Uhr
>> *Von:* "Javier Jimenez Shaw" <j1 at jimenezshaw.com>
>> *An:* "proj" <PROJ at lists.osgeo.org>, "Peter Löwe" <peter.loewe at gmx.de>
>> *Betreff:* PROJ was not updated in Zenodo
>> Hi PROJ
>> I "was" by accident in Zenodo today, and I think it was not updated
>> with the last release of PROJ
>> https://zenodo.org/records/10818825
>> Is it still failing, Peter?
>> Cheers
>> Javier
>> .___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
>> PROJ mailing list
>> https://lists.osgeo.org/mailman/listinfo/proj
> http://www.spatialys.com
> My software is free, but my time generally not.
> PROJ mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240619/a185fee5/attachment.htm>
More information about the PROJ
