[PROJ] PROJ was not updated in Zenodo
Even Rouault
even.rouault at spatialys.com
Tue Jun 4 07:25:42 PDT 2024
I've posted the following message through Zenodo support form at
https://zenodo.org/support
The PROJ project has released a new GitHub release at
https://github.com/OSGeo/PROJ/releases/tag/9.4.1 a couple days ago but
no new corresponding Zenodo record has been created at
https://zenodo.org/records/5884394 , despite the GitHub integration
being set up.
I see from my account in https://zenodo.org/account/settings/github/
that the repository seems to have been disabled, although it was enabled
last time. It seems something regularly disable repositories... ? I've
just re-enabled it (as well as other repositories such as OSGeo/gdal and
mapserver/mapserver that were disabled). Could you trigger the creation
of a new record for the 9.4.1 release ? And what's the reason for this
apparent disabling of repositories? This isn't the first time it happens
Best regards,
Even Rouault
I'm proposing to add a step in HOWTO-RELEASE so we check that before
doing the release : https://github.com/OSGeo/PROJ/pull/4162 , pending
Zenodo figures out why the repositories get regularly disabled...
Even
Le 04/06/2024 à 12:20, Peter Löwe via PROJ a écrit :
> Javier, all,
> whoever handled the latest release should contact the Zenodo helpdesk
> https://zenodo.org/support about the missing version DOI.
> BTW, the PROJ page at OSGeo (https://www.osgeo.org/projects/proj/)
> seems to be outdated (PROJ 9.0.0).
> Best,
> Peter
> <peter.loewe at gmx.de>
> *Gesendet:* Montag, 03. Juni 2024 um 21:56 Uhr
> *Von:* "Javier Jimenez Shaw" <j1 at jimenezshaw.com>
> *An:* "proj" <PROJ at lists.osgeo.org>, "Peter Löwe" <peter.loewe at gmx.de>
> *Betreff:* PROJ was not updated in Zenodo
> Hi PROJ
> I "was" by accident in Zenodo today, and I think it was not updated
> with the last release of PROJ
> https://zenodo.org/records/10818825
> Is it still failing, Peter?
> Cheers
> Javier
> .___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
> PROJ mailing list
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240604/68d54d2d/attachment.htm>
More information about the PROJ
