[PROJ] conda + qgis + PROJ
Javier Jimenez Shaw j1 at jimenezshaw.com
Thu Jun 13 14:52:34 PDT 2024
Hi
I am trying to run QGIS (from conda) using the PROJ version I just compiled
(master)
I thought that LD_LIBRARY_PATH should be enough, but this is not taking the
compiled libproj.so, but the one from conda:
LD_LIBRARY_PATH=/home/jshaw/work/PROJ/build/lib
/home/jshaw/anaconda3/envs/qgis_stable/bin/qgis
How should I do it? I do not want to compile QGIS, only to link with my
version of PROJ.
Thanks
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240613/af9ef38b/attachment.htm>
More information about the PROJ mailing list
