[PROJ] conda + qgis + PROJ
Even Rouault even.rouault at spatialys.com
Thu Jun 13 15:15:02 PDT 2024
Javier,
this is because Conda builds have the RPATH set to "$ORIGIN/../lib"
$ readelf -d ~/miniconda3/envs/gdal_master_env/bin/gdalinfo | grep RPATH
  0x000000000000000f (RPATH)              Library rpath: [$ORIGIN/../lib]
And apparently this has priority over LD_LIBRARY_PATH
You can try something like the following
install the "chrpath" utility ("chrpath" package on Debian/Ubuntu)
cp /home/jshaw/anaconda3/envs/qgis_stable/bin/qgis
/home/jshaw/anaconda3/envs/qgis_stable/bin/qgis_no_rpath
chrpath -d /home/jshaw/anaconda3/envs/qgis_stable/bin/qgis_no_rpath
LD_LIBRARY_PATH=/home/jshaw/work/PROJ/build/lib:/home/jshaw/anaconda3/envs/qgis_stable/lib
Or mess with with the content of
/home/jshaw/anaconda3/envs/qgis_stable/lib, to symlink its libproj.so.25
to yours
Even
Le 13/06/2024 à 23:52, Javier Jimenez Shaw via PROJ a écrit :
> Hi
> I am trying to run QGIS (from conda) using the PROJ version I just
> compiled (master)
> I thought that LD_LIBRARY_PATH should be enough, but this is not
> taking the compiled libproj.so, but the one from conda:
> How should I do it? I do not want to compile QGIS, only to link with
> my version of PROJ.
> Thanks
> .___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240614/d8c1de5a/attachment.htm>
More information about the PROJ mailing list
