[PROJ] Is there a cmake way to change the library name?
Even Rouault even.rouault at spatialys.com
Mon Jun 24 05:35:03 PDT 2024
Le 24/06/2024 à 07:23, Carl Godkin via PROJ a écrit :
> Hi,
> We use PROJ 9.3.1 in our software.
> I built it with cmake using curl and libtiff for Windows 64.
> I also needed to build a minimal version to be used in a plugin to
> another application where I cannot use curl and I've done that
> successfully.
> But both DLLs (i.e., the "regular" one and the "minimal" one) are
> named "proj_9_3.dll"
> I would love to change the DLL name of one of them but I don't see a
> cmake variable for doing that.  I am not a cmake expert by any means,
> so perhaps I missed something.
No, you didn't miss anything. This isn't configurable. But you can
easily change it by modifying the value of the OUTPUT_NAME at line
https://github.com/OSGeo/PROJ/blob/4aa16151b98926fbbe6d8504a770379c6733ac35/src/lib_proj.cmake#L417
I suspect you could also probably override it after the fact by calling
PROJ's CMakeLists.txt from a CMakeLists.txt of yours and doing a
"set_target_properties(proj PROPERTIES OUTPUT_NAME "your_name")"
afterwards, but I'm not totally sure about that.
> I imagine I could get into the generated makefiles for my minimal
> version but editing cmake-generated makefiles is not really a
> sustainable solution.
> Is there a way to specify the DLL name?
> I have the same question for GDAL but figured I'd start with the
> simpler-to-build PROJ library.
GDAL has actually a CMake cache variable to customize this:
GDAL_LIB_OUTPUT_NAME
> Thanks a lot,
> carl
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240624/87db337e/attachment.htm>
More information about the PROJ mailing list
