[PROJ] Is there a cmake way to change the library name?
Carl Godkin
cgodkin at gmail.com
Sun Jun 23 22:23:53 PDT 2024
We use PROJ 9.3.1 in our software.
I built it with cmake using curl and libtiff for Windows 64.
I also needed to build a minimal version to be used in a plugin to another
application where I cannot use curl and I've done that successfully.
But both DLLs (i.e., the "regular" one and the "minimal" one) are named
"proj_9_3.dll"
I would love to change the DLL name of one of them but I don't see a cmake
variable for doing that. I am not a cmake expert by any means, so perhaps
I missed something.
I imagine I could get into the generated makefiles for my minimal version
but editing cmake-generated makefiles is not really a sustainable solution.
Is there a way to specify the DLL name?
I have the same question for GDAL but figured I'd start with the
simpler-to-build PROJ library.
Thanks a lot,
carl
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240623/56bf38d4/attachment.htm>
More information about the PROJ
