[PROJ] Is there a cmake way to change the library name?
Carl Godkin cgodkin at gmail.com
Tue Jun 25 16:16:44 PDT 2024
Hi Greg,
I'm not following what you're suggesting here.
The plugin I'm building is for another vendor's software and they don't use
GDAL or PROJ already in their main program.  But they do use (an older
version of ) libcurl.  Our normal PROJ and GDAL depend on an up-to-date
libcurl.
I've called my minimal (w/o curl) versions of PROJ and GDAL
"proj_9_3-minimal.dll" and "gdal-minimal.dll."
We haven't had a problem with the approach I've described.   What problem
am I flirting with here, or what should I do differently?  Sorry to be
dense!
Thanks a lot,
carl
On Tue, Jun 25, 2024 at 9:07 AM Greg Troxel via PROJ <proj at lists.osgeo.org>
wrote:
> Carl Godkin via PROJ <proj at lists.osgeo.org> writes:
> > On Tue, Jun 25, 2024 at 7:27 AM Javier Jimenez Shaw <j1 at jimenezshaw.com>
> > wrote:
> >> One question
> >> Are you linking the same GDAL (or final binary) with both versions of
> >> PROJ? If that is the case, I think it would be undefined behaviour.
> > No, I am not linking anything to both versions of PROJ.
> > Our main apps link to both GDAL and PROJ (i.e., the "full" versions of
> > both).
> > This plugin links to GDAL (the minimal one) and PROJ (minimal also, and
> the
> > version the minimal GDAL was built with).
> Plugins are generally dynamically loaded, so there really needs to be
> library compat with the host/main program.
> I would recommend having an entirely separate prefix for older/different
> versions, and to build everything within each prefix, not crossing.
> > use.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240625/b865bfd3/attachment.htm>
More information about the PROJ mailing list
