[PROJ] Is there a cmake way to change the library name?
Carl Godkin
cgodkin at gmail.com
Tue Jun 25 16:38:05 PDT 2024
Hi Greg,
Your assumptions are all correct.
And fortunately the other vendor's app doesn't use SQLite at all. (Phew!)
Thanks for checking. It's a pain but our customers like our plugin so we
have to keep building it!
carl
On Tue, Jun 25, 2024 at 4:28 PM Greg Troxel via PROJ <proj at lists.osgeo.org>
wrote:
> Carl Godkin via PROJ <proj at lists.osgeo.org> writes:
> > I'm not following what you're suggesting here.
> I am suggesting keeping the two worlds totally separate.
> > The plugin I'm building is for another vendor's software and they don't
> use
> > GDAL or PROJ already in their main program. But they do use (an older
> > version of ) libcurl. Our normal PROJ and GDAL depend on an up-to-date
> > libcurl.
> > I've called my minimal (w/o curl) versions of PROJ and GDAL
> > "proj_9_3-minimal.dll" and "gdal-minimal.dll."
> > We haven't had a problem with the approach I've described. What problem
> > am I flirting with here, or what should I do differently? Sorry to be
> > dense!
> Having read that, I think you are ok. I am assuming:
> Your gdal-minimal.dll links to proj_9_3-minimal
> the plugin links to $other_vendor's libs and gdal-minimal.dll
> there are no programs on the computer that link to both gdal.dll and
> gdal-minimal.dll
> I would tend to separate these by prefix, rather than name, but I don't
> use windows and I gather the windows dll world is very difficult to deal
> with.
> From my experience in packaging, I see situations where the base system
> has one version of a library; let's call it sqlite3 :-) But that base
> version is either too old, or lacks rtree, and some package wants the
> better one. But the package also wants heimdal (kerberos), which is
> from base, and that links to base sqlite. This is the sort of problem
> that is all too easy to run into. But it sounds like you are aware of
> it and avoiding it, and for now I think you are. You are though, on
> thin ice, and the next wrinkle may push you over the edge.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240625/d8b406b8/attachment.htm>
More information about the PROJ
