[PROJ] is really "-t" needed in projinfo?
Even Rouault even.rouault at spatialys.com
Mon May 6 04:04:24 PDT 2024
Le 06/05/2024 à 12:34, Javier Jimenez Shaw via PROJ a écrit :
> Hi
> Some times when I am using cs2cs I want to do also a projinfo, to see
> the transformation(s) that is may apply.
> It is always bothering me that I have to add "-s" and "-t".
> Looking at the documentation I see that "-s" is not there any more.
Accidental removal in the doc. Fixed per
https://github.com/OSGeo/PROJ/pull/4134
> Does it make sense that if there are two args without option
> identifier, it assumes that the second is "-t"? Am I missing some
> corner-cases? (if you like the idea, I am happy to do the PR)
> I do not mean to remove "-t" completely, but to make the arg parser
> more flexible.
I don't foresee any issue in allowing -s -t to be implicit
Even
http://www.spatialys.com
More information about the PROJ mailing list
