[PROJ] WGS 84 to GDA2020 in EPSG
Javier Jimenez Shaw j1 at jimenezshaw.com
Thu May 9 03:47:51 PDT 2024
Hi
Preparing a talk for FOSS4G Europe in Tartu (see you there if you come!), I
found that the 3 transformations  in EPSG from WGS 84 to GDA2020 (2, 3 and
4) they all have 3m accuracy.
That is not giving a clue to PROJ about which one is better.
(2) is a null Helmert transformation.
(3) is a Helmert with 7 numbers
(4) uses a grid.
Is there anybody from the Australian agency here? Is there any reason why
the three transformations have the same accuracy? I would expect different
values. I looks like a copy-paste issue.
The same happens with the transformation from WGS 84 to GDA94.
Thanks,
Javier
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240509/afdd71b7/attachment.htm>
More information about the PROJ mailing list
