[PROJ] Make push and pop FIFO?
Thomas Knudsen
knudsen.thomas at gmail.com
Tue May 7 05:40:22 PDT 2024
Jochem,
You're most welcome to submit a PR with a solution that fits your needs.
Otherwise, I believe the solution to the problem you mention is to have a
geometric national system, which you link to the global with a Helmert
operation, then a separate step for the geometric-to-geophysical.
Alternatively, use a pipeline, which will hide the axisswap steps from the
end user.
Den tirs. 7. maj 2024 kl. 14.23 skrev Lesparre, Jochem via PROJ <
proj at lists.osgeo.org>:
> Hi Even,
> For the 3 islands of the Dutch Caribbean we have 2 islands with a
> time-dependent transformation (with no geoid yet) and 1 island with a (not
> yet time-dependent) transformation with a geoid. Using the 4th component
> and axisswap for the height would be too confusing. Moreover, we are going
> to introduce a time-dependent transformation for the third island as soon
> as possible.
> The combination of a 7-parameter transformation and a geoid is the most
> basic transformation from an international 3D geographic CRS to a national
> projected CRS and a national physical height system. Don’t you find it
> troublesome that PROJ needs a workaround for that? I really hope you will
> be able to choose an approach soon, even if it isn’t entirely your taste.
> Jochem
> Disclaimer:
> De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd voor de
> geadresseerde(n).
> Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of
> verstrekking van deze informatie aan derden is niet toegestaan.
> Op al onze producten en diensten zijn onze algemene leveringsvoorwaarden
> van toepassing
> [https://www.kadaster.nl/algemene-leveringsvoorwaarden].
> Disclaimer:
> This email and any files transmitted with it are confidential and intended
> solely for the use of the individual or entity to whom they are addressed.
> If you are not the intended recipient, you are notified that disclosing,
> copying, distributing or taking any action in reliance on the contents of
> this information is strictly prohibited.
> Our general terms and conditions of delivery apply to all our products and
> services
> [https://www.kadaster.com/general-terms-and-conditions].
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240507/9bbf24ac/attachment.htm>
More information about the PROJ
