[PROJ] Sndyer Map Projections Manual in HTML form
strebe at aol.com
strebe at aol.com
Mon May 27 15:00:25 PDT 2024
Hello Mircea.
This is an impressive work that does much honor John Snyder’s legacy. Thank you for what must have been a huge effort. I will be making use of it as needed.
Regards,— Daniel “daan” Strebe
On Saturday, March 30, 2024 at 04:01:23 PM PDT, Mircea Neacsu via PROJ <proj at lists.osgeo.org> wrote:
Hello,
My work of converting Snyder – Map Projection Manual to HTML is almost finished. Probably the most interesting part are the numerical examples, implemented using JavaScript. All formulas can be recalculated, and one can see all the intermediate steps and the result of those calculations.
I would very much like to hear your comments. Given the number of formulas, I’m sure there are many errors that have slipped through, and I will be grateful if you will point those out.
Thank you,
Mircea Neacsu
PROJ mailing list
PROJ at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240527/2d92f02b/attachment.htm>
More information about the PROJ
