[PROJ] Sndyer Map Projections Manual in HTML form
Mircea Neacsu
mircea at neacsu.net
Tue May 28 03:45:28 PDT 2024
That would be up to proj.org to decide but I think it needs a bit more validation. Javier Jimenez found a few bugs and surely there may be some more.
Thank you for the encouragement; means a lot to me.
Mircea Neacsu
---- On Tue, 28 May 2024 03:06:15 -0400 José Luis García Pallero <jgpallero at gmail.com> wrote ---
Thank tou very much for this amazing work. I think the link must be added to the http://proj.org References section
El martes, 28 de mayo de 2024, Mircea Neacsu via PROJ <mailto:proj at lists.osgeo.org> escribió:
mailto:jgpallero at gmail.com
(o<
V_/_
Use Debian GNU/Linux and enjoy!
Hello Daan,
Thank you for your kind words. If you encounter any errors or other problems, please let me know.
Cheers,
Mircea Neacsu
---- On Mon, 27 May 2024 18:00:25 -0400 <mailto:strebe at aol.com> wrote ---
Hello Mircea.
This is an impressive work that does much honor John Snyder’s legacy. Thank you for what must have been a huge effort. I will be making use of it as needed.
Regards,
— Daniel “daan” Strebe
On Saturday, March 30, 2024 at 04:01:23 PM PDT, Mircea Neacsu via PROJ <mailto:proj at lists.osgeo.org> wrote:
Hello,
My work of converting https://neacsu.net/docs/geodesy/snyder/ to HTML is almost finished. Probably the most interesting part are the https://neacsu.net/docs/geodesy/snyder/numerics/, implemented using JavaScript. All formulas can be recalculated, and one can see all the intermediate steps and the result of those calculations.
I would very much like to hear your comments. Given the number of formulas, I’m sure there are many errors that have slipped through, and I will be grateful if you will point those out.
Thank you,
Mircea Neacsu
PROJ mailing list
mailto:PROJ at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240528/c9210503/attachment.htm>
More information about the PROJ
