[PROJ] Sndyer Map Projections Manual in HTML form
José Luis García Pallero
jgpallero at gmail.com
Tue May 28 00:06:15 PDT 2024
Thank tou very much for this amazing work. I think the link must be added
to the proj.org References section
El martes, 28 de mayo de 2024, Mircea Neacsu via PROJ <proj at lists.osgeo.org>
escribió:
> Hello Daan,
> Thank you for your kind words. If you encounter any errors or other
> problems, please let me know.
> Cheers,
> Mircea Neacsu
> ---- On Mon, 27 May 2024 18:00:25 -0400 * <strebe at aol.com
> <strebe at aol.com>>* wrote ---
> Hello Mircea.
> This is an impressive work that does much honor John Snyder’s legacy.
> Thank you for what must have been a huge effort. I will be making use of it
> as needed.
> Regards,
> — Daniel “daan” Strebe
> On Saturday, March 30, 2024 at 04:01:23 PM PDT, Mircea Neacsu via PROJ <
> proj at lists.osgeo.org> wrote:
> Hello,
> My work of converting Snyder – Map Projection Manual
> <https://neacsu.net/docs/geodesy/snyder/> to HTML is almost finished.
> Probably the most interesting part are the numerical examples
> <https://neacsu.net/docs/geodesy/snyder/numerics/>, implemented using
> JavaScript. All formulas can be recalculated, and one can see all the
> intermediate steps and the result of those calculations.
> I would very much like to hear your comments. Given the number of
> formulas, I’m sure there are many errors that have slipped through, and I
> will be grateful if you will point those out.
> Thank you,
> Mircea Neacsu
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
(o<
V_/_
Use Debian GNU/Linux and enjoy!
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240528/ca53ccc9/attachment-0001.htm>
More information about the PROJ
