[PROJ] PROJ (and GDAL) webpages
Even Rouault
even.rouault at spatialys.com
Sat Nov 16 05:35:02 PST 2024
> Wouldn't it be easier with a "tag" ? Just set (or re-set with -f) the
> tag "stable" to the needed commit (that can be another tag, like "9.5.1")
Yes tagging the new commit in 9.5 as "stable" would be slightly quicker.
But that *can't* be labelled as 9.5.1, because we issue such SemVer tags
to match official releases (with a tarball etc).
I've finally successfully experimented some automation with a workflow
that automatically refreshes the tag when a push is done in the 9.5
branch. See https://github.com/OSGeo/PROJ/pull/4323 and
https://github.com/OSGeo/PROJ/pull/4324. This adds 2 extra steps when
creating a new maintenance branch, but apart from that, that should be
transparent afterwards.
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20241116/2243a11c/attachment-0001.htm>
More information about the PROJ
