[PROJ] PROJ (and GDAL) webpages
Javier Jimenez Shaw j1 at jimenezshaw.com
Sat Nov 16 09:26:20 PST 2024
Sounds good.
Do we still need this line?
"Also update the redirect for `/* -> /en/X.Y/:splat` at ..."
On Sat, 16 Nov 2024 at 14:35, Even Rouault <even.rouault at spatialys.com>
wrote:
> Wouldn't it be easier with a "tag" ? Just set (or re-set with -f) the tag
> "stable" to the needed commit (that can be another tag, like "9.5.1")
> Yes tagging the new commit in 9.5 as "stable" would be slightly quicker.
> But that *can't* be labelled as 9.5.1, because we issue such SemVer tags to
> match official releases (with a tarball etc).
> I've finally successfully experimented some automation with a workflow
> that automatically refreshes the tag when a push is done in the 9.5 branch.
> See https://github.com/OSGeo/PROJ/pull/4323 and
> https://github.com/OSGeo/PROJ/pull/4324. This adds 2 extra steps when
> creating a new maintenance branch, but apart from that, that should be
> transparent afterwards.
> http://www.spatialys.com
> My software is free, but my time generally not.
> Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20241116/30b7a080/attachment.htm>
More information about the PROJ mailing list
