[PROJ] PROJ (and GDAL) webpages
Even Rouault
even.rouault at spatialys.com
Sat Nov 16 09:36:05 PST 2024
Le 16/11/2024 à 18:26, Javier Jimenez Shaw a écrit :
> Sounds good.
> Do we still need this line?
> "Also update the redirect for `/* -> /en/X.Y/:splat` at ..."
Indeed, no, mention removed in
https://github.com/OSGeo/PROJ/pull/4324/commits/bb24e728cce9cbcce165808b95d41e671d1a045c
And one-time configuration changed added in
https://github.com/OSGeo/PROJ/pull/4323#issuecomment-2480678212
> On Sat, 16 Nov 2024 at 14:35, Even Rouault
> <even.rouault at spatialys.com> wrote:
>> Wouldn't it be easier with a "tag" ? Just set (or re-set with -f)
>> the tag "stable" to the needed commit (that can be another tag,
>> like "9.5.1")
> Yes tagging the new commit in 9.5 as "stable" would be slightly
> quicker. But that *can't* be labelled as 9.5.1, because we issue
> such SemVer tags to match official releases (with a tarball etc).
> I've finally successfully experimented some automation with a
> workflow that automatically refreshes the tag when a push is done
> in the 9.5 branch. See https://github.com/OSGeo/PROJ/pull/4323 and
> https://github.com/OSGeo/PROJ/pull/4324. This adds 2 extra steps
> when creating a new maintenance branch, but apart from that, that
> should be transparent afterwards.
> http://www.spatialys.com
> My software is free, but my time generally not.
> Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20241116/a422d438/attachment.htm>
More information about the PROJ
