[PROJ] PROJ (and GDAL) webpages
Even Rouault
even.rouault at spatialys.com
Mon Nov 18 04:56:18 PST 2024
Should be fixed per
https://github.com/OSGeo/PROJ/commit/7fd0162a9b3ec3032d943390f6d4fd6aeab5bf6b
(based on hint at
https://docs.readthedocs.io/en/stable/reference/robots.html#tool-integration)
... BUT ... unfortunately, there seems to be issues on RTD side that I
don't know how to solve. With the 'stable' tag, it has only seen the
(now dangling) initial commit of that tag, and not the further updates.
I've just tried to create instead a 'stable' branch, and this is a bit
similar in that the build of it in
https://app.readthedocs.org/projects/osgeo-proj/builds/26313882/ sees as
'stable' the state of the '9.5' branch at time it was created in
september
(https://github.com/OSGeo/PROJ/commit/0a407325fbb5bf42407a7dc5d4f948be9707e302)
and not the actual state of the github repo
(https://github.com/OSGeo/PROJ/tree/stable) . But if you look at the
history of
https://app.readthedocs.org/projects/osgeo-proj/builds/?version__slug=stable
, you can see that at some point it tried to build commit
https://github.com/OSGeo/PROJ/commit/34cfbeb650529e153059880f34ce01dd73d9b5cf
( the actual 'stable' github branch), but that was when I temporarily
swtiched back the active version to the 9.5 branch instead of stable. So
it seems the state of stable in RTD is only updated to its latest github
state when it is *not* the default version. Or something like that...
Seems like a bug. It looks a bit like this is similar to
https://github.com/readthedocs/readthedocs.org/issues/11768 . I've no
more idea on how to solve that. I've s/spend quite a bunch/burnt too
much/ time on this... Want to take the stick on ... ?
Le 18/11/2024 à 12:24, Javier Jimenez Shaw a écrit :
> Thank you Even for the changes done!
> Somehow related are the robots.txt.
> How are they managed in RTD?
> In GDAL there "was" something (for latest, not for stable)
> https://web.archive.org/web/20241027091118/https://gdal.org/robots.txt
> but gone on Nov 1st
> https://web.archive.org/web/20241101132800/https://gdal.org/robots.txt
> I do not find anything related in the code of GDAL. Is it managed
> internally in RTD settings? (I don't have access to that)
> I would suggest to have something like this:
> User-agent: *
> Allow: /en/stable/
> Disallow: /en/
> Sitemap:https://proj.org/sitemap.xml
> Cheers
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20241118/156c1a13/attachment.htm>
More information about the PROJ
