[PROJ] PROJ (and GDAL) webpages
Even Rouault even.rouault at spatialys.com
Mon Nov 18 05:37:26 PST 2024
... actually ... disregard my below BUT.  The latest RTD build of
'latest'
(https://app.readthedocs.org/projects/osgeo-proj/builds/26314172/)
actually caught up with the state of the 'latest' github branch (
https://github.com/OSGeo/PROJ/commit/8df3845d1896dd21e9270d99ecae31703fe79c4b
== https://github.com/OSGeo/PROJ/commits/stable/   at time of writing ).
That said, there's a RTD UI glitch which was the reason of my confusion.
If you go to https://app.readthedocs.org/projects/osgeo-proj/builds/ ,
and put your mouse over the "[icon] stable [green tick]" button towards
the right of the "Version stable" line, a popup window appears with a
"Branch" link whose label is 'stable' but it resolves to
https://github.com/OSGeo/PROJ/tree/9.5.0/)
And now:
$ curl https://proj.org/robots.txt
User-agent: *
Allow: /en/stable/
Disallow: /en/
Sitemap: https://proj.org/sitemap.xml
So things seem to work fine ... for now ... To monitor that this remains
... stable
Le 18/11/2024 à 13:56, Even Rouault via PROJ a écrit :
> Should be fixed per
> https://github.com/OSGeo/PROJ/commit/7fd0162a9b3ec3032d943390f6d4fd6aeab5bf6b
> (based on hint at
> https://docs.readthedocs.io/en/stable/reference/robots.html#tool-integration)
> ... BUT ... unfortunately, there seems to be issues on RTD side that I
> don't know how to solve. With the 'stable' tag, it has only seen the
> (now dangling) initial commit of that tag, and not the further
> updates. I've just tried to create instead a 'stable' branch, and this
> is a bit similar in that the build of it in
> https://app.readthedocs.org/projects/osgeo-proj/builds/26313882/ sees
> as 'stable' the state of the '9.5' branch at time it was created in
> september
> (https://github.com/OSGeo/PROJ/commit/0a407325fbb5bf42407a7dc5d4f948be9707e302)
> and not the actual state of the github repo
> (https://github.com/OSGeo/PROJ/tree/stable) . But if you look at the
> history of
> https://app.readthedocs.org/projects/osgeo-proj/builds/?version__slug=stable
> , you can see that at some point it tried to build commit
> https://github.com/OSGeo/PROJ/commit/34cfbeb650529e153059880f34ce01dd73d9b5cf
> ( the actual 'stable' github branch), but that was when I temporarily
> swtiched back the active version to the 9.5 branch instead of stable.
> So it seems the state of stable in RTD is only updated to its latest
> github state when it is *not* the default version. Or something like
> that...  Seems like a bug. It looks a bit like this is similar to
> https://github.com/readthedocs/readthedocs.org/issues/11768 . I've no
> more idea on how to solve that. I've s/spend quite a bunch/burnt too
> much/ time on this... Want to take the stick on ... ?
> Le 18/11/2024 à 12:24, Javier Jimenez Shaw a écrit :
>> Thank you Even for the changes done!
>> Somehow related are the robots.txt.
>> How are they managed in RTD?
>> In GDAL there "was" something (for latest, not for stable)
>> https://web.archive.org/web/20241027091118/https://gdal.org/robots.txt
>> but gone on Nov 1st
>> https://web.archive.org/web/20241101132800/https://gdal.org/robots.txt
>> I do not find anything related in the code of GDAL. Is it managed
>> internally in RTD settings? (I don't have access to that)
>> I would suggest to have something like this:
>> User-agent: *
>> Allow: /en/stable/
>> Disallow: /en/
>> Sitemap:https://proj.org/sitemap.xml
>> Cheers
> http://www.spatialys.com
> My software is free, but my time generally not.
> Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20241118/6a5387d1/attachment-0001.htm>
More information about the PROJ mailing list
