[PROJ] PROJ 9.5.1RC1 & PROJ-data 1.20RC1
Kristian Evers kristianevers at gmail.com
Tue Nov 26 00:10:59 PST 2024
In anticipation of the releases scheduled for December 1st, I have prepared release candidates
for both PROJ and PROJ-data. Download the archives here:
https://download.osgeo.org/proj/proj-9.5.1RC1.tar.gz
https://download.osgeo.org/proj/proj-9.5.1RC1.zip
https://download.osgeo.org/proj/proj-data-1.20RC1.tar.gz
https://download.osgeo.org/proj/proj-data-1.20RC1.zip
The PROJ-data adds grids for use in Hungary and Thüringen, Germany.
See the release notes for PROJ below.
As always, please test the release candidates and report any issues you may find. Either here on the mailing list or on GitHub.
/Kristian
# PROJ Release Notes
## 9.5.1
### Updates
* Database: update to EPSG v11.021 (#4254, #4275, #4297)
* Speed-up dramatically proj.db build time (#4280)
* Database: ingest deprecated ESRI names to be able to better import old WKT ESRI (#4282)
### Bug fixes
* `findsOpsInRegistryWithIntermediate()`: Restrict to using known source/target CRS that have the same originating authority (#4252)
* `isTimeDependent()`: Do not mark "static" Coordinate Frame helmert transformations as time-dependent, only time-dependent ones (#4259)
* Fix clang-19 "warning: empty paragraph passed to '@throw' command [-Wdocumentation]" (#4263)
* WKT importer: fix `nullptr` dereference on invalid `VERTCS[]` (#4266)
* Fixed `sql_filelist.cmake` relative path issue (#4296)
* Fail consistently on network error and grid transformations (#4302)
* Fix `-Wshadow` warnings between `parammappings.cpp` and `singleoperation.cpp` with unity builds (#4304)
* Removed leftover setting of `CMAKE_REQUIRED_FLAGS` (#4322)
* WKT1 ESRI export: fix wrong mapping of Lambert Cylindrical Equal Area to Behrmann (#4328)
* Numerous documentation fixes (#4248, #4267, #4291, #4293)
More information about the PROJ mailing list
