[PROJ] Alternative PROJJSON implementations?
Javier Jimenez Shaw j1 at jimenezshaw.com
Mon Oct 21 13:14:36 PDT 2024
Hi Howard,
as you already know, spatialreference.org is generating the PROJJSON
output. As a curiosity, some of the data displayed for the CRS in the html
page is extracted directly from the PROJJSON (the axes info IIRC. I was
thinking on adding more stuff, but stopped there).
Best regards
Javier
On Mon, 21 Oct 2024 at 22:03, Howard Butler via PROJ <proj at lists.osgeo.org>
wrote:
> All,
> I am participating in the OGC CRS SWG [1] who is currently investigating
> the standardization of a JSON-based CRS definition such as PROJJSON [2].
> One question that came up in our discussion is whether or not there are any
> alternative software implementations of PROJJSON besides PROJ's itself. Did
> you write one? Are you using PROJJSON in commercial or open source software
> that isn't PROJ-based? Is forward/backward compatibility of PROJJSON a
> priority for you? Information about these questions would be useful for us
> to know regarding possible enhancement or evolution of PROJJSON going
> forward.
> There was also some interest in knowing where PROJJSON has been used in
> unexpected or unintentional ways. Are you using it as the CRS definition
> for your custom format or network protocol? We know of it being used by
> GeoParquet at the moment, but are there others?
> Please help inform our discussion around standardization of JSON-based CRS
> definitions with some feedback on your use of PROJJSON in the wild.
> Regards,
> Howard
> [1] https://github.com/opengeospatial/CRS-JSON-Encoding
> [2] https://proj.org/specifications/projjson.html
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20241021/f4e36439/attachment.htm>
More information about the PROJ mailing list
