[PROJ] Alternative PROJJSON implementations?
Sean Gillies sean.gillies at gmail.com
Mon Oct 21 13:25:08 PDT 2024
Howard,
Rasterio's command line programs accept PROJ4 style JSON objects like
{"proj": "longlat", "datum": "WGS84", ...}. This goes back to 2014. It's
literally the old PROJ4 key/value encoding, but as JSON. Nothing more.
Rasterio has accepted PROJJSON since 2021.
Yours,
On Mon, Oct 21, 2024 at 2:15 PM Howard Butler via PROJ <proj at lists.osgeo.org>
wrote:
> All,
> I am participating in the OGC CRS SWG [1] who is currently investigating
> the standardization of a JSON-based CRS definition such as PROJJSON [2].
> One question that came up in our discussion is whether or not there are any
> alternative software implementations of PROJJSON besides PROJ's itself. Did
> you write one? Are you using PROJJSON in commercial or open source software
> that isn't PROJ-based? Is forward/backward compatibility of PROJJSON a
> priority for you? Information about these questions would be useful for us
> to know regarding possible enhancement or evolution of PROJJSON going
> forward.
> There was also some interest in knowing where PROJJSON has been used in
> unexpected or unintentional ways. Are you using it as the CRS definition
> for your custom format or network protocol? We know of it being used by
> GeoParquet at the moment, but are there others?
> Please help inform our discussion around standardization of JSON-based CRS
> definitions with some feedback on your use of PROJJSON in the wild.
> Regards,
> Howard
> [1] https://github.com/opengeospatial/CRS-JSON-Encoding
> [2] https://proj.org/specifications/projjson.html
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20241021/8fd148eb/attachment.htm>
More information about the PROJ mailing list
