[PROJ] general use of proj_factors
Even Rouault
even.rouault at spatialys.com
Fri Oct 25 04:14:23 PDT 2024
> You will note that this is the implementation of EPSG:3006, but
> without +type=crs. Why without that parameter? Time. When including
> it, the proj_factors call takes around 60 times longer.
Should be fixed per https://github.com/OSGeo/PROJ/pull/4289
Even
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20241025/5d6083f5/attachment.htm>
More information about the PROJ
