[PROJ] general use of proj_factors
Roger Oberholtzer
roger.oberholtzer at gmail.com
Fri Oct 25 05:24:05 PDT 2024
On Fri, Oct 25, 2024 at 1:14 PM Even Rouault <even.rouault at spatialys.com> wrote:
> You will note that this is the implementation of EPSG:3006, but
> without +type=crs. Why without that parameter? Time. When including
> it, the proj_factors call takes around 60 times longer.
> Should be fixed per https://github.com/OSGeo/PROJ/pull/4289
Fantastic! I can't wait to try it! I'm running 9.4.x. When do you
guess it might be in a release?
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
Roger Oberholtzer
More information about the PROJ
