[PROJ] general use of proj_factors
Even Rouault
even.rouault at spatialys.com
Fri Oct 25 05:39:37 PDT 2024
Le 25/10/2024 à 14:24, Roger Oberholtzer a écrit :
> On Fri, Oct 25, 2024 at 1:14 PM Even Rouault<even.rouault at spatialys.com> wrote:
>> You will note that this is the implementation of EPSG:3006, but
>> without +type=crs. Why without that parameter? Time. When including
>> it, the proj_factors call takes around 60 times longer.
>> Should be fixed perhttps://github.com/OSGeo/PROJ/pull/4289
> Fantastic! I can't wait to try it! I'm running 9.4.x. When do you
> guess it might be in a release?
I've queued it for 9.6.0 March next year. Could potentially be
backported to 9.5 but I'd be a bit nervous to do that in a bugfix
release because it might break people (ab)using proj_factors() by
calling it from multiple threads on the same PJ* object.
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20241025/83b7fb1e/attachment.htm>
More information about the PROJ
