[PROJ] Geodetic to Authalic latitude conversions
Jérôme St-Louis
jerome at ecere.com
Tue Sep 10 18:19:20 PDT 2024
Hi Even, all,
As suggested in https://github.com/OSGeo/PROJ/pull/4211 , I've just
written an implementation of the authalic / geodetic latitude conversion
with the goal to automatically perform this conversion when using ISEA
with an non-spherical ellipsoid, and was wondering whether we would want
to improve the PROJ version (/pj_authlat()/ for the geodetic ==>
authalic), which is used for ISEA, but also by:
- Equal Area Cylindrical (cea.cpp)
- EqualEarth (eqearth.cpp)
- HEALPix (healpix.cpp) -- which might also imply rHEALPix
- Lambert Azimuthal Equal Area (laea.cpp)
The current version of /pj_authlat()/ uses a series expansion based on
the eccentricity squared (I believe this is based on a Lagrange
reversion <https://en.wikipedia.org/wiki/Lagrange_inversion_theorem> as
mentioned here
<https://en.wikipedia.org/wiki/Latitude#Inverse_formulae_and_series>),
and Charles Karney in this paper <https://arxiv.org/pdf/2212.05818>
establishes that:
> /series expansions using the third flattening as the small parameter
> uniformly result in smaller truncation errors compared to using the
> eccentricity./
The current version also only uses order 3, whereas GeographicLib would
normally use order 6 for double precision, with order 4 being the
minimum configuration.
The current order 3, which requires 2 /sin()/ calls, gives precision up
to roughly 8 decimals.
Order 6 would mean twice the number of /sin()/ calls, and the 8 decimals
should be enough to point to Waldo on a page <https://xkcd.com/2170/>,
however C.K. argues that:
> /Modern geodetic libraries should strive to achieve full
> double-precision accuracy /(page 4)/
and I would much agree with that.
Based on the direction we want to go, I would submit a PR including
adjustments to avoid the separate heap allocation for the doubles (as
discussed here
<https://github.com/OSGeo/PROJ/pull/4211#pullrequestreview-2233903246>),
and adjustments for tests etc.
PROJ currently does not use the full GeographicLib which already
includes code for conversion between different auxiliary latitudes, does it?
https://github.com/geographiclib/geographiclib/blob/main/src/AuxLatitude.cpp
See my proposed new version below, which I wrote based on equation 20 on
page 3, and matrix A20 on page 13 from the paper, applying optimizations
similar to the current /pj_authlat()/.
Kind regards,
-Jerome
> void pj_authset(double a, double b, double cp[6])
> // https://arxiv.org/pdf/2212.05818
> // ∆η(ζ) = S^(L)(ζ) · Cηζ · P^(M) (n) + O(n^L+1) -- (20)
> double n = (a - b) / (a + b); // Third flattening
> static const double C[21] = // (A20)
> 4 / 3.0, 4 / 45.0, -16/35.0, -2582 /14175.0, 60136
> /467775.0, 28112932/ 212837625.0,
> 46 / 45.0, 152/945.0, -11966 /14175.0, -21016 /
> 51975.0, 251310128/ 638512875.0,
> 3044/2835.0, 3802 /14175.0, -94388 /
> 66825.0, -8797648/ 10945935.0,
> 6059 / 4725.0, 41072 /
> 93555.0, -1472637812/ 638512875.0,
> 768272
> /467775.0, -455935736/ 638512875.0,
> 4210684958/1915538625.0
> double p;
> cp[0] = C[ 0] * n;
> p = n * n;
> cp[0] += C[ 1] * p;
> cp[1] = C[ 6] * p;
> p *= n;
> cp[0] += C[ 2] * p;
> cp[1] += C[ 7] * p;
> cp[2] = C[11] * p;
> p *= n;
> cp[0] += C[ 3] * p;
> cp[1] += C[ 8] * p;
> cp[2] += C[12] * p;
> cp[3] = C[15] * p;
> p *= n;
> cp[0] += C[ 4] * p;
> cp[1] += C[ 9] * p;
> cp[2] += C[13] * p;
> cp[3] += C[16] * p;
> cp[4] = C[18] * p;
> p *= n;
> cp[0] += C[ 5] * p;
> cp[1] += C[10] * p;
> cp[2] += C[14] * p;
> cp[3] += C[17] * p;
> cp[4] += C[19] * p;
> cp[5] = C[20] * p;
> double pj_authlat(double auth, const double * cp)
> double a2x = auth + auth, a4x = a2x + a2x, a8x = a4x + a4x;
> return auth +
> cp[0] * sin(a2x) +
> cp[1] * sin(a4x) +
> cp[2] * sin(a4x + a2x) +
> cp[3] * sin(a8x) +
> cp[4] * sin(a8x + a2x) +
> cp[5] * sin(a8x + a4x);
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240910/8866f84c/attachment.htm>
More information about the PROJ
