[PROJ] PROJ 9.5.0RC1 & PROJ-data 1.19RC1
Kristian Evers kristianevers at gmail.com
Sun Sep 15 04:15:47 PDT 2024
With +1’s from
Kristian
Javier
Even
Howard
Alan
Charles
I declare the motion passed. Release announcement to come within the next couple of hours.
/Kristian
> On 13 Sep 2024, at 20.13, Charles Karney <charles.karney at gmail.com> wrote:
> +1
>  --Charles
> On Fri, Sep 13, 2024 at 2:38 AM Kristian Evers via PROJ
> <proj at lists.osgeo.org> wrote:
>> PSC members,
>> No issues have been reported with either of the release candidates so I’ll
>> put their promotion to final releases up for a vote.
>> I’ll start with my +1.
>> /Kristian
>>> On 9 Sep 2024, at 14.01, Kristian Evers <kristianevers at gmail.com> wrote:
>>> All,
>>> in preparation for a new round of PROJ and PROJ-data release I have uploaded release candidates for both packages.
>>> Download the archives here:
>>> https://download.osgeo.org/proj/proj-9.5.0RC1.tar.gz
>>> https://download.osgeo.org/proj/proj-9.5.0RC1.zip
>>> https://download.osgeo.org/proj/proj-data-1.19RC1.tar.gz
>>> https://download.osgeo.org/proj/proj-data-1.19RC1.zip
>>> The PROJ release includes various updates and bug fixes. See the release notes below.
>>> The PROJ-data release is updated with grids related to the Greenlandic GLMSL and GLLAT.
>>> Please test the release candidates and report any issues you may find with them.
>>> Either here on the mailing list or on GitHub.
>>> /Kristian
>>> ## 9.5.0
>>> ### Updates
>>> * Database: add constraint for unicity of CRS and operation names (#4071)
>>> * Make a few more functions that accept a `PJ*` to actually acccept a `const PJ*` (#4074)
>>> * Database: Increase consistency in trigger checks (#4080)
>>> * Speed-up `+proj=cart +inv` (#4087)
>>> * Added EPSG:9656 "Cartesian Grid Offsets" operation method, and imported related records (#4094)
>>> * Add a `WKTParser::grammarErrorList()` method so that `proj_create_from_wkt()` can behave as documented (#4108)
>>> * `CRS::stripVerticalComponent()`: Redirect it to `demoteTo2D(std::string(), nullptr)` (#4127)
>>> * Add `proj_context_set_user_writable_directory()` to public API (#4144)
>>> * CMake: for Windows builds, defaults PROJ DLL to be just `proj_${PROJ_MAJOR_VERSION}.dll` (#4167)
>>> * Add `toWGS84AutocorrectWrongValues()` method and use it in PROJ.4 and WKT1 CRS import (#4172)
>>> * WKT import: add support for Oracle WKT "Albers_Conical_Equal_Area" spelling (#4181)
>>> * Limit number of C++ exceptions thrown & caught internally (#4183)
>>> * Database: update to EPSG 11.016 (#4241)
>>> * CMake: add option `EMBED_PROJ_DATA_PATH` (#4207)
>>> * Add SEA Inverse projection (#4211)
>>> * projinfo: Add 2 args equivalent to usage of `-s` and `-t` (#4218)
>>> * CMake: add TESTING_USE_NETWORK configure option (#4220)
>>> * Add `PROJ_ERR_COORD_TRANSFM_MISSING_TIME` and `proj_coordoperation_requires_per_coordinate_input_time()` (#4221)
>>> * Add new Conversion "Local Orthographic" (#4228, #4229)
>>> * Add data/ITRF2020 with ITRF2020 to ITRFother, and ITRF2020 plate motion models (#4235)
>>> ### Bug Fixes
>>> * Fix `imoll` and `imoll_o` zone calculations to correct inverse transformations near the "seams" (#4159)
>>> * Fix wrong EPSG conversion code for UTM south (#4166)
>>> * BoundCRS::exportToPROJ(): handle case of NADCON conus grid (#4168)
>>> * `+proj=gridshift`: make projected grids work with `PROJ_NETWORK=ON` (#4174)
>>> * `createOperations()`: make it work when transforming from/to a CompoundCRS with a DerivedVerticalCRS with ellipsoidal height (#4176)
>>> * Support default context as `nullptr` in `CoordinateTransformer` (#4177)
>>> * cct: emit error message and return error code when not being able to open input file (#4200)
>>> * Fix race condition surrounding DB reopening during fork (#4231)
>>> * `GeographicBoundingBox::create()`: accept degenerate bounding box reduced to a point or a line (#4237)
>>> * `createOperation()`: tune so that ITRF2000->ETRS89 does not return only NKG grid based operations but also time-dependent Helmert (#4244)
>> PROJ mailing list
>> PROJ at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/proj
> Charles Karney <karney at alum.mit.edu>
> 702 Prospect Ave
> Princeton, NJ 08540
More information about the PROJ mailing list
