[PROJ] Transformations in ITRF2020
    Lesparre, Jochem
    Jochem.Lesparre at kadaster.nl
    Wed Sep 18 02:53:31 PDT 2024
> Looking at the pipelines, the steps would be ITRF2020 -> ETRF2020 -> ETRS89 -> CH1903+
I am pretty sure Switzerland uses ETRF2000 as ETRS89 realisation, not ETRF2020. So, the correct transformation would be:
ITRF2020 -> ETRF2000 -> ETRS89 -> CH1903+
The difference between ETRF2000 and ETRF2020 is about 7 cm. ETRF2000 is recommended for use by national mapping agencies.
Jochem
From: PROJ <proj-bounces at lists.osgeo.org> On Behalf Of Javier Jimenez Shaw via PROJ
Sent: dinsdag 27 augustus 2024 19:30
To: proj <PROJ at lists.osgeo.org>
Subject: [PROJ] Transformations in ITRF2020
Hi
I am now facing transformations with ITRF2020 with time(yes, because Skylark, but I guess more NTRIPs are going to do (or already doing) the same)
The point is when the destination CRS does not have a direct transformation from ITRF2020 (or almost).
For instance, EPSG:4150, CH1903+ (the geographic of LV95, in Switzerland) is only connected to ETRS89. See that CH1903+ is in the European tectonic plate, as ETRS89
A direct transformation is completely ballpark
echo 42 6 0 2024.6 | ./cs2cs EPSG:9989 EPSG:4150 -d 9 --3d
42.000000000 6.000000000 0.000000000 2024.6
However, from ITRF2020 to ETRS89 there is some change due to the time (the European plate moving at 2.5 cm/a since 2015):
echo 42 6 0 2024.6 | ./cs2cs EPSG:9989 EPSG:4937 -d 9 --3d
41.999994981 5.999991317 -0.001861237 2024.6
and from ETRS89 to CH1903+ due to the datum offset:
echo 42 6 0 2024.6 | ./cs2cs EPSG:4937 EPSG:4150 -d 9 --3d
42.000742733 6.000670188 -60.682799297 2024.6
(btw, only since PROJ 9.4.1, when ETRF2020 was added)
I understand that the only way to get the proper transformation is chaining these two manually. Via ETRS89 ... because I know it. Right?
Well, the future does not look so promising to me: in EPSG I only see transformations from ITRF2020 to ETRF family, NAD83(2011) family and NAD83(CSRS)v8. That is Europe, USA and Canada. That's all, folks.
Thanks,
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
Javier Jimenez Shaw
Mercator str 42.
Null-Island
Disclaimer:
De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd voor de geadresseerde(n).
Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of verstrekking van deze informatie aan derden is niet toegestaan.
Op al onze producten en diensten zijn onze algemene leveringsvoorwaarden van toepassing
[https://www.kadaster.nl/algemene-leveringsvoorwaarden].
Disclaimer:
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Our general terms and conditions of delivery apply to all our products and services
[https://www.kadaster.com/general-terms-and-conditions].
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240918/27f96576/attachment-0001.htm>
More information about the PROJ
