[PROJ] Transformations in ITRF2020
Javier Jimenez Shaw j1 at jimenezshaw.com
Wed Sep 18 09:36:16 PDT 2024
Aren't they using CHTRS95 ?
https://epsg.org/crs_4933/CHTRS95.html
On Wed, 18 Sept 2024 at 11:53, Lesparre, Jochem <Jochem.Lesparre at kadaster.nl>
wrote:
> > Looking at the pipelines, the steps would be ITRF2020 -> ETRF2020 ->
> ETRS89 -> CH1903+
> I am pretty sure Switzerland uses ETRF2000 as ETRS89 realisation, not
> ETRF2020. So, the correct transformation would be:
> ITRF2020 -> ETRF2000 -> ETRS89 -> CH1903+
> The difference between ETRF2000 and ETRF2020 is about 7 cm. ETRF2000 is
> recommended for use by national mapping agencies.
> Jochem
> *From:* PROJ <proj-bounces at lists.osgeo.org> *On Behalf Of *Javier Jimenez
> Shaw via PROJ
> *Sent:* dinsdag 27 augustus 2024 19:30
> *To:* proj <PROJ at lists.osgeo.org>
> *Subject:* [PROJ] Transformations in ITRF2020
> Hi
> I am now facing transformations with ITRF2020 with time(yes, because
> Skylark, but I guess more NTRIPs are going to do (or already doing) the
> same)
> The point is when the destination CRS does not have a direct
> transformation from ITRF2020 (or almost).
> For instance, EPSG:4150, CH1903+ (the geographic of LV95, in Switzerland)
> is only connected to ETRS89. See that CH1903+ is in the European tectonic
> plate, as ETRS89
> A direct transformation is completely ballpark
> echo 42 6 0 2024.6 | ./cs2cs EPSG:9989 EPSG:4150 -d 9 --3d
> 42.000000000 6.000000000 0.000000000 2024.6
> However, from ITRF2020 to ETRS89 there is some change due to the time (the
> European plate moving at 2.5 cm/a since 2015):
> echo 42 6 0 2024.6 | ./cs2cs EPSG:9989 EPSG:4937 -d 9 --3d
> 41.999994981 5.999991317 -0.001861237 2024.6
> and from ETRS89 to CH1903+ due to the datum offset:
> echo 42 6 0 2024.6 | ./cs2cs EPSG:4937 EPSG:4150 -d 9 --3d
> 42.000742733 6.000670188 -60.682799297 2024.6
> ETRS89 -> CH1903+
> (btw, only since PROJ 9.4.1, when ETRF2020 was added)
> I understand that the only way to get the proper transformation is
> chaining these two manually. Via ETRS89 ... because I know it. Right?
> Well, the future does not look so promising to me: in EPSG I only see
> transformations from ITRF2020 to ETRF family, NAD83(2011) family and
> NAD83(CSRS)v8. That is Europe, USA and Canada. That's all, folks.
> Thanks,
> .___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
> Javier Jimenez Shaw
> Mercator str 42.
> Null-Island
> Disclaimer:
> De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd voor de
> geadresseerde(n).
> Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of
> verstrekking van deze informatie aan derden is niet toegestaan.
> Op al onze producten en diensten zijn onze algemene leveringsvoorwaarden
> van toepassing
> [https://www.kadaster.nl/algemene-leveringsvoorwaarden].
> Disclaimer:
> This email and any files transmitted with it are confidential and intended
> solely for the use of the individual or entity to whom they are addressed.
> If you are not the intended recipient, you are notified that disclosing,
> copying, distributing or taking any action in reliance on the contents of
> this information is strictly prohibited.
> Our general terms and conditions of delivery apply to all our products and
> services
> [https://www.kadaster.com/general-terms-and-conditions].
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240918/36d14d56/attachment.htm>
More information about the PROJ mailing list
