[PROJ] robots.txt
Javier Jimenez Shaw
j1 at jimenezshaw.com
Fri Sep 20 07:09:11 PDT 2024
On Fri, 20 Sept 2024, 16:05 Even Rouault, <even.rouault at spatialys.com>
wrote:
> Le 20/09/2024 à 15:54, Javier Jimenez Shaw a écrit :
> > Coming back to the question about
> > "What should we index for PROJ: /en/latest/ or /en/stable/ ?"
> > Now that I have clear what is what, I would say that robots.txt should
> > include only "en/stable"
> Yes, ideally. The annoying part is that currently it points to the state
> of the 9.5.0 tag that doesn't point to the 9.5.0 release tarball...
If it is complicated or ugly we can do it for 9.5.1.
> IIRC, gdal has "latest" because at that point in time (and today as
> > well) there is no stable available yet, only latest.
> > BTW, is there any reason why in GDAL the "Read the Docs" menu is on
> > the right, and not in the left as in PROJ? (I prefer as in PROJ)
> Already ticketed as https://github.com/OSGeo/gdal/issues/10680 . I
> suspect this is due to GDAL using a custom Sphinx theme (derived from
> one made by late Boundless, itself derived from the official RtD one,
> due to a past Boundless employee who helped bootstrapping the Sphinx
> migration). I guess just using the standard RtD theme would be a way to
> fix this.
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240920/f6c5186c/attachment.htm>
More information about the PROJ
