[PROJ] downloadable documentation ?
Even Rouault
even.rouault at spatialys.com
Sat Sep 21 16:23:02 PDT 2024
> Is there a stable URL, where I can be guaranteed of the same bits for a
> repeat request, in the same way that a distribution tarball is fixed?
> It seems like this is a nightly build of the 9.5 branch, but I'm not
> sure.
Currently /stable points to the latest tag (9.5.0):
https://proj.org/_/downloads/en/stable/pdf/
That will change to 9.5.1 docs once 9.5.1 is released
> Where are the sources?
"make latexpdf" from the docs/ directory, using the full tarball of
https://github.com/OSGeo/PROJ/archive/refs/tags/9.5.0.tar.gz that
includes that directory
See doc/environment.yml for the various built requirements (here using
conda-forge package naming, but should map in a straightforward way in
other packaging solutions)
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240922/e321816a/attachment.htm>
More information about the PROJ
