[PROJ] Big grid files - side tracking the conversation
Javier Jimenez Shaw
j1 at jimenezshaw.com
Mon Apr 28 05:49:00 PDT 2025
On Mon, 28 Apr 2025 at 13:35, Mircea Neacsu <mircea at neacsu.net> wrote:
> Apologies for my side tracking:
> >During the summit I asked about the interpolation method. The metadata
> says that it should be biquadratic. The answer was: "for the undulation
> there is almost no difference.
> > But for other magnitudes, like vertical deflection, it is more
> noticeable. However, to match our values you have to do biquadratic
> interpolation"
> Do you know any reason, apart from historical ones, to use the biquadratic
> interpolation? I did a short writeup on different interpolation methods
> <https://neacsu.net/docs/programming/2d-interpolation-functions/> and,
> from what I can see, the biquadratic method is the worst possible one.
No, I do not know the reason. I asked my contact in the summit. I will
share the answer if I get any.
There is people from the NOAA subscribed to this mailing list. They are
usually quiet ;)
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20250428/ba653224/attachment.htm>
More information about the PROJ
