[PROJ] The extent of EPSG:4326 is Douglas County, Wisconsin, according to proj.db
Javier Jimenez Shaw
j1 at jimenezshaw.com
Sat Feb 1 23:46:27 PST 2025
It is from
https://epsg.org/extent_4326/USA-Wisconsin-Douglas.html
If there is a mistake in EPSG, you can connect them in their page.
On Sun, 2 Feb 2025, 08:27 William Temperley via PROJ, <proj at lists.osgeo.org>
wrote:
> I'm a little confused as to why the extent of EPSG:4326 is given as Douglas County in Wisconsin, in proj.db
> https://github.com/OSGeo/PROJ/blob/master/data/sql/extent.sql#L3305
> INSERT INTO "extent" VALUES('EPSG','4326','USA - Wisconsin - Douglas','United States (USA) - Wisconsin - Douglas county.',46.15,46.76,-92.3,-91.55,0);
> Best regards,
> Will Temperley
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20250202/7cf294c4/attachment.htm>
More information about the PROJ
