[PROJ] The extent of EPSG:4326 is Douglas County, Wisconsin, according to proj.db
Javier Jimenez Shaw
j1 at jimenezshaw.com
Sat Feb 1 23:51:29 PST 2025
Oh. I think I misunderstood.
That extent has the id 4326. But you want the extent of the crs EPSG:4326.
The numbers of different types can be repeated
In https://epsg.org/crs_4326/WGS-84.html
you can see that its extent has id 2830, that is
https://epsg.org/extent_2830/World-by-country.html
On Sun, 2 Feb 2025, 08:46 Javier Jimenez Shaw, <j1 at jimenezshaw.com> wrote:
> It is from
> https://epsg.org/extent_4326/USA-Wisconsin-Douglas.html
> If there is a mistake in EPSG, you can connect them in their page.
> On Sun, 2 Feb 2025, 08:27 William Temperley via PROJ, <
> proj at lists.osgeo.org> wrote:
>> I'm a little confused as to why the extent of EPSG:4326 is given as Douglas County in Wisconsin, in proj.db
>> https://github.com/OSGeo/PROJ/blob/master/data/sql/extent.sql#L3305
>> INSERT INTO "extent" VALUES('EPSG','4326','USA - Wisconsin - Douglas','United States (USA) - Wisconsin - Douglas county.',46.15,46.76,-92.3,-91.55,0);
>> Best regards,
>> Will Temperley
>> PROJ mailing list
>> PROJ at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20250202/ffe0b755/attachment.htm>
More information about the PROJ
