[PROJ] failing tests
    Even Rouault
    even.rouault at spatialys.com
    Tue Jan 21 15:24:24 PST 2025
> But that happens in both OK and KO builds... A workaround could
> perhaps be to try force using SQLite3 from Conda ?
just tried that in
https://github.com/rouault/PROJ/commit/b2b3e3897094b312532310b6240a6685e077f4c5
https://github.com/rouault/PROJ/actions/runs/12897666174/job/35963244002
: doesn't work unfortunately
> Comparing the logs show no obvious differences in runner version,
> compilers or third party libraries. So this is totally mysterious. I
> guess someone with access to a Mac will probably have to look at that
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20250122/b027edd3/attachment.htm>
More information about the PROJ
