[PROJ] failing tests
    Even Rouault
    even.rouault at spatialys.com
    Wed Jan 22 05:24:15 PST 2025
ok, looking closer there was a difference. conda-forge has updated from
sqlite 3.47.2 to 3.48.0 and this is a upstream sqlite 3.48.0 regression
I've reported at https://sqlite.org/forum/forumpost/36bbc86546
Le 22/01/2025 à 00:24, Even Rouault via PROJ a écrit :
>> But that happens in both OK and KO builds... A workaround could
>> perhaps be to try force using SQLite3 from Conda ?
> just tried that in
> https://github.com/rouault/PROJ/commit/b2b3e3897094b312532310b6240a6685e077f4c5
> https://github.com/rouault/PROJ/actions/runs/12897666174/job/35963244002
> : doesn't work unfortunately
>> Comparing the logs show no obvious differences in runner version,
>> compilers or third party libraries. So this is totally mysterious. I
>> guess someone with access to a Mac will probably have to look at that
> http://www.spatialys.com
> My software is free, but my time generally not.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20250122/af805e6c/attachment.htm>
More information about the PROJ
